Beatdowncity
I did a pressure test on the coolant system, got it to hold at 14 PSI and i saw no leaks anywhere.
I looked up in the hole for the PVC on the rear of the sc, it looked wet. SO i took off the top of what i assume is the PVC system(circled in red) and looking inside after i took out a few parts it was wet inside as well.
So what i am understanding now is coolant is getting sucked up through the lim, into the PVC system in the SC and then the coolant is getting put back into the airflow and that is why my lim looks so wet, and possible why i am getting white smoke with the IC installed.
