Hi guys, I tried to search for this but couldn't find an answer specifically to my issue, so i apologize in advance for asking something that's probably been answered already..
I have a 2004 Pontiac Grand Prix GT with 100k miles. The coolant has never been changed (my bad), so I am assuming it still has DexCool in it. I am slowly losing coolant, and the heat intermittently stops working. It also intermittently overheats. It also needs a little throttle some mornings to start, but otherwise runs fine. Is there a way to distinguish between a head gasket leak or an intake manifold leak? It seems like LIM issues are way more common than head gasket issues, but the heater issue leads me to believe that there is air in the system. Is it possible for air to get into the coolant system VIA the LIM, without the car running like absolute garbage and throwing codes? Also, how would you recommend thoroughly flushing the DexCool out of my system to switch to Green?
Many Thanks!
Dan
Many Thanks!
Dan
