98GPGT2D
Well, as always, I used the Search button before making a new thread. Problem is, all the threads I read about Coolant Elbows are for the most part, conflicting.
So, here it is...the question..
Do you have to remove the Lower Intake in order to replace the coolant elbows?
Also, a couple threads I read said the elbows can be found in the "Help Section" We have that section in the Canadian Tire stores here up in Canada, but does anyone know the actual part numbers to look for IN the help section? There's a few PVC elbows in that section.
The upper elbow on the 97 Grandprix I just bought it leaking and needs replaced. From what I read disconnect the battery, remove alternator, couple bolts that hold that bracket on...remove the bracket..remove the broken pieces..clean up with emery, lube o-rings, reassemble? Im going to do the valve cover gaskets at the same time.
Thanks for looking,
Jay
Thanks for looking,
Jay
