coolant elbows. Yes, coolant elbows
All I know is, after having one of the plastic elbows explode on me while driving...I feel much better having metal ones in there!
I'm not sure I agree....you may be right, but the flip side is that we don't know what the metal elbows are made of, they are some sort of aluminum alloy which may or may not have corrosion issues. Also, the only thing that holds these elbows in the hole is the O-ring, there's no metal-to-metal contact for seating or sealing purposes where corrosion would make it difficult to remove.
I am *hoping* that the Dorman engineers took these things into account when they designed the elbows, but only time will tell I guess. Besides, if they don't leak there is no need to remove them :)
any time you have 2 different types of metal put together, there is always a chance of some kind of corrosion.
i just did my lim gaskets, the upper elbow was less then a year old ( plastic) that O ring was almost flat, and the tube was quite snug in the holes.
if you never saw a corrosion problem by mating 2 types of metal together, its a mess. and sometimes one of the metals looses out, and corrodes away.
ever use a galvanized nail in copper? with in year the hole in the copper from the nail will be twice the size of the puncture, and where the head meets the copper, it will corrode.
and al and cast dont mix either. they are chromed looking, so that may save them from this, but if they are polished AL it could happen, ive yet to have a set im my hands.
like Bill said its a waiting game to see how they work out.
I see crud build up around the plastic ones.. I know it's not corrision..but crud is crud and I'm just saying.....let's hope I'm wrong.
I like this thread because it makes me feel young again. Because when I started it I was. Oh what a difference a year makes.
It doesn't take a year....I've nailed a copper hot water pipe with a finish nailer shooting galvanized finish nails while installing baseboard molding. You never know you hit the pipe because the nail seals the hole perfectly....for about 2 weeks, then it starts to drip. The first thing I saw was the puddle in the basement....when I pulled off the drywall it was already misting from the hole. Point is it doesn't take a year for the galvanic reaction to start.
I got a flat on the Suburban back when it was new. So I jack it up to put the spare on....and the rear wheel will not come off. All 8 lugs off, laying on the ground kicking it with my boot and nothing. Alloy wheels corroded solid to the face of the steel brake rotor. Wound up filling it with air and driving over to my buddy's shop so they could beat it with a BMFH tool. I now know to smear a little anti-sieze on the back of the wheel when re-installing. Interesting I replaced the factory alloys with American Racing alloys and no longer have the problem...different alloy composition?
So I completely agree that there *could* be an issue, all I'm saying is that I'm betting there won't be since I have 2 sets of these installed.....
add water or moisture to the equation and corrosion speeds up big time, the 2 metals make a electronic charge, and then one gets eaten.
if you were to use regular nails to hold the copper straps to hold the pipes to the wall studs, so they dont shake, the nails will corrode a lot slower. but still rot out over time, and sooner or later the pipes will start to rattle.
on them 8 lug wheels, i always used anti-seize on the lugs and back of the rear wheels to the hub. ( you want some between the lug and wheel too) i also towed my boat, and dunked the ass end in the salt water river 4 times a weekend. ( wheels deep) lugs would lock up, and the wheel got stuck once. never a problem again after using anti-seize.
heres one for ya, next high way trip you take in your truck, when you stop, go feel how hot the back tires are, vs the fronts, i have no idea why this happens, but my back tires/wheels were always way hotter then the fronts. i think the heat has something to do with the back wheels locking on. i noticed this with my 97 and 03 GMC p/u's both 4x4, happened with the factory wheels and the 33's i put on both of them. only had a problem with the aftermarket al wheels. the steel wheels always came off.
the heat would burn off tire shine faster too, very odd. fronts still looked great, the rears all dull and dirty looking..
Not sure on the method you want to use for installing the elbows. On my 97 I used a fair amount of RTV and it leaks on the LIM side. On my 99 I didn't use any and it never leaked...so I dunno.
Well, not to hijack this thread any further than it is....I've noticed the rear wheel temps when towing the RV. My theory is that the diff fluid circulates out through the axle tubes to lube the wheel bearings on a full floater, and the hot diff fluid is what makes the wheels so hot. After a long pull at 70 mph, they will burn your hand if you touch them.
that was my only thought as well, like what else could be getting the tires hot, never mind the whole wheel as well. mine both got hot no matter what, much warmer/hotter then the fronts.
