Comp G springs
These are your money shot part numbers for CompG springs.
These numbers are a guarantee because I just read them off my old 2004 CompG spring tags.
TDK 10258881
FKJ 22133030
Happy hunting
TDK 10258881
FKJ 22133030
Happy hunting
Thank you good sir! And to everyone else that has helped!
All but gxp comp g have fe1 springs
Does the GXP springs raise the height? I know I've heard the struts and springs do but I didn't know if GXP springs would raise it if on, either comp g struts or KGB struts.where do you all usually buy your struts like comp g ones? Rock auto? GM parts direct?? Amazon? How much should I expect a strut to be?
Thank you for your help!!
I bought mine in April from RockAuto. They had a good deal on the rears. For the fronts I looked around and it was hard to find 2 from the same place. So I went Rockauto for the fronts too. They still shipped from 2 different warehouses.
Use RockAuto to find the numbers and do some googles to find the best deal.
They are usually close to 100 to 125 apiece.
Happy hunting
about 50k id assume like the comp g spring there slightly stiffer, however can't confirm if these will raise or not
