just loosen the top bolts and put washers behind them and tilt it up. That's what I did and it works great. Or get the bonneville bracket, which I plan on installing soon.
That's what I'm doing. I custom made a metal P/S upper engine mount because the necessary aluminum L36 Impala upper mounts break too easy. Keep that in mind.
I had it done a while back but just installed a cam and when i idle it makes a squeaky noise and tried to tighten the washers but still has little play side to side so maybe the bolt aint fitting right
Sam - every intercooled car youve ever seen in person had their coil packs spaced the way I did yours =p. Next time I see you I will check it out and make sure its tight and not squeaking. .
