hammerline81
Okay thanks lol
You will have to do some cutting and work if you build your own. Pre-built coilovers are available by Intense and Arraut Motorsports, but they can be costly.
Boots on the Bilsteins won't work, you will need to get the covers (unless someone else can say different)
Helper springs aid in rebound stability through corners and over road imperfections. They also serve the additional function of keeping the main spring under proper preload. Basically a little better ride, because they will compress at a softer rate over the main spring which will be more for body roll. If I could do it over again...I would get these.
Genesis guides I have no idea, this is new to me.
Like I said these require a little work to have and keep; a good alternative is Bilsteins with lowering springs. I drove in the snow on SSC's....and my Saab sits lower than that and I drive that in the snow without issue.
There are different forms of lowering, there is the stock height because people think potholes and snow will make it all impossible and they will die; there is the optimal performance where you have just a 1.5-2" drop just enough to put the struts and car at the position to feel comfortable yet controllable, which is accomplished with either springs or coilovers(this goes even further when you get struts and springs in a paired values, but Grand Prix's don't really have that, so don't ask), then there is the full monty where you drop the car to stupid lows, potholes, snow, and even pebbles be damned and suspension geometry means nothing.
Every car since my Saturn...has been option 2....the Grand Prix was option 3. LOL
Basically you need to decide, how much you want to invest, how much time you have to involve yourself with this project, and what you really want out of the car (be it handling or looks).
Yeah. We build a lot of home made things so we aren't lacking in things like that. Drill presses, cylinder press, etc. I don't know how to work the lathe though... too complicated for me lol I say it's a shaft polisherDude if you have all that **** you can get this done in a hour or two
This car burnt down and the headlights are complete **** anyways. Never again haha!If you do this....please ditch the ebay headlights LOL
