code P0401
Try Googling if you don't know a code. I find Gearchatter has most of the FSM on their site and it's open. Therefore you can get the diagnostic aids etc. Great stuff.
DTC P0401
CIRCUIT DESCRIPTION
The powertrain control module (PCM) tests the exhaust gas recirculation (EGR) system during deceleration. The PCM does this by momentarily commanding the EGR valve to open while monitoring the signal circuit of the manifold absolute pressure (MAP) sensor. When the EGR valve is opened, the PCM will expect to see a predetermined increase in MAP. If the expected increase in MAP is not detected, the PCM records the amount of MAP difference that was detected and adjusts a calibrated fail counter towards a calibrated fail threshold level. The number of EGR flow test counts required to exceed the fail threshold may vary according to the amount of detected EGR flow error.
Normally, the PCM will only allow one EGR flow test during an ignition cycle. To aid in verifying a repair, the PCM will allow up to 16 EGR flow test counts during the first ignition cycle following a code clear event. Between 9-16 EGR flow test counts should be sufficient for the PCM to determine adequate EGR flow and pass the EGR flow test. If the PCM detects an EGR flow error, DTC P0401 sets.
DTC DESCRIPTOR
This diagnostic procedure supports the following DTC:
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
CONDITIONS FOR RUNNING THE DTC
* DTCs P0068, P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0120, P0201, P0202, P0203, P0204, P0205, P0206, P0220, P0300, P0335, P0403, P0404, P0405, P0502, P0503, P0506, P0507, P0604, P0606, P0641, P0651, P1106, P1107, P1125, P2101, P2108, and P2135 are not set.
* The engine run time may need to be more than 2 minutes .
* The Ignition 1 Signal parameter is between 11-18 volts .
* The AC Relay Command parameter does not change.
* The EGR position is less than 1 percent .
* The transmission is in 3rd or 4th gear.
* The Current Gear parameter does not change.
* The Intake Air Temperature (IAT) Sensor parameter is between -7°C and +100°C (+19°F and +212°F) .
* The Engine Coolant Temperature (ECT) Sensor parameter is between 75-126°C (167-259°F) .
* The Engine Speed parameter is between 1,000-1,500 RPM .
* The Manifold Absolute Pressure (MAP) Sensor parameter is between 17-43 kPa, 20-43 kPa for supercharged.
* The Barometric Pressure (BARO) parameter is more than 74 kPa .
* The Throttle Position (TP) Sensor parameter is less than 1 percent .
* The Vehicle Speed Sensor parameter is between 45-113 km/h (28-70 mph) during deceleration.
* The Idle Air Control (IAC) Position parameter does not change more than 3 counts while the above conditions are met.
* The vehicle will need to be driven more than 80 km/h (50 mph) , and then allowed to decelerate. When the vehicle is decelerating, while meeting all of the criteria listed above, the PCM will enable the EGR flow test to run. As the EGR flow test is running, you will see the Desired EGR Position parameter and the EGR Position Sensor parameter on the scan tool momentarily change from 0 to a calibrated value above 0. Additionally, the EGR Flow Test Count parameter on the scan tool will increment when each EGR flow test is completed.
CONDITIONS FOR SETTING THE DTC
The MAP changes monitored by the PCM during the EGR flow tests indicate an insufficient amount of EGR flow.
ACTION TAKEN WHEN THE DTC SETS
* The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
* The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
* The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
* A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
* A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
* Clear the MIL and the DTC with a scan tool.
DIAGNOSTIC AIDS
Inspect for the following conditions:
* A vacuum restriction to the MAP sensor-A skewed MAP sensor reading can cause the PCM to read incorrect MAP changes during the EGR flow test.
* An engine that is running poorly due to a mechanical condition such as worn piston rings, worn camshaft, etc.-These types of conditions can cause low engine vacuum and thus can cause a less than expected MAP changes during the flow test.
* Excessive back pressure in the exhaust system may cause this DTC to set. This condition can cause low engine vacuum and thus can cause a less than expected MAP changes during the EGR flow test. Possible causes of this could be a restriction in the exhaust system or non original equipment manufacture (OEM) exhaust parts.
* Exhaust system leaks can cause an insufficient amount of EGR flow through the EGR valve. This condition can cause a less than expected MAP changes due to insufficient exhaust back pressure. Possible causes of this could be a leaking exhaust system, a leaking EGR pipe, or non original equipment manufacture (OEM) exhaust parts.
* A restriction in the intake manifold such as carbon deposits and casting flash
TEST DESCRIPTION
