Ok, I'm a dummy so I need some help with this one. I've got an 04' GTP with 135k miles. Starting to clear a clunking or knocking noise when I accelerate from a stop, or shift from park-drive or to reverse. Sounds like its coming from the front end drivers side. Occasionally it will occur while driving if I hit a bump, but usually not. Does not usually happen when turning. When accelerating from a stop, its more like a series of groans or creaking. Switching gears its more like a single 'pop' or 'clunk.'
At first I thought maybe a motor or trans mount, but If I'm accelerating while already at speed I hear nothing. When I pop the hood and have someone rev the engine it does not move much. It moves more when shifting gears, so maybe the trans mount? I jacked up the car and took a look at it. The transmission mounting bracket was pretty rusty, but the mount itself looked OK. Not sure if it would be easily visible if it did need replacing, however. The trans moves a little bit, but I don't know how much movement is abnormal. I took a video and did notice the wheel bearing assembly does rotate when switching gears and knocks against the rotor, maybe this play is normal and I'm just clueless or if its indicative of something else like a bad CV joint or wheel bearing. I'd appreciate it if someone could provide some input, thanks.
Sorry for the crappy video quality.
View My Video
View My Video
