Clunking from front and rear.
cameron92
Grand Pricks
Every bump I go over the rear driver side makes a loud clunking sound and when climbing in the trunk the other day to fix my sub it clunked again. I am thinking its the strut, but how can I tell for sure?
Also I noticed the other day when backing out with the wheel turned right, the car jumps a little like something is loose. Any idea what that could be?
And finally, when turning and pressing the gas there is a clunk in the steering wheel.
Any help is appreciated, car is a 2006 Grand Prix.
Sway bar links (in the front) connect the sway bar to the control arm. If you look behind the wheel, you should see the sway bar connected to the control arm with a long both that has poly spacers on it. If the spacers are crushed/deformed, the link is bad. These are cheap and easy to replace yourself. Check those for the fronts. In the rear, could be something similar or could be a strut/strut mount. Check to see if the car "bounces" when you give it a push test. Push down on the rear of the car to get it moving, and keep pushing up and down until it's moving. Let go and see if it continues to bounce a couple of times, or if it stops quickly. If it continues to bounce, your struts are shot. Clunking could also be the strut mount itself.
or the rear end links or rear sway bar bushings. with the back tires off you can see them clear as day, or back up on ramps and slide under to look at them.
Another clunk source in the front could be the control arm bushings. Lower control arms for our cars are like $40 a piece, and not too bad to change out.
I'll have to check all that when it warms up a bit here, - 20 and snowing right now lol. The car definitely doesnt bounce when pressing down on it or going over bumps, just makes the clunking sound from the strut tower.
Sent from my HTC One using Tapatalk
Check your rear strut towers and make sure they're not rusted out...if they're solid, I'd say you have bad strut mounts if you hear it while climbing in the trunk, and it sounds like it's IN the trunk.
No there not rusted.
Does anyone know the warranty for the electronic rust control modules?
you need a air gun and a spring compressor. i went and bought a pair for my front struts, took the struts out and dropped them off at a font end shop and paid 25 or 30 for them to change them. its the safe way to get it done. let a pro do it lol
What's the mileage on the car? Might just be worth it to replace the entire strut assemblies. No special tools needed - they sell the entire thing in a one piece unit. Grand total of 5 bolts each.
You have to take the struts out to put new mounts on anyway...maybe save up a bit and put new struts all the way around...
