Burley117
Here's the issue:
My fiances 98 GP GT has clunk in the front right wheel area. When we let off the brakes, the clunk happens. It will also rattle when we hit bumps on the road. I couldn't see anything in the wheel end that looked broken so I took it to the mechanic. He couldn't find anything wrong! He said all the suspension components and linkages were tight but seems to think it is in the brakes. A friend mentioned that it could be the U-clamps or grommets that hold stablizer to the frame. But no confirmation on that yet.
Mechanics Theory: The caliper piston is bad and that's what causes the clunk.
Solution: Replace front brakes, and calipers.
My Theory: I haven't taken the brakes off yet, but seems that maybe the pad is loose and rattling around. Hence it's fine when we brake but clunks when we let off the pedal.
Solution: Replace pad.
Obviously I don't want to spend a small fortune doing front brakes and calipers if it's just the pad. Again, these are just theories as I haven't taken the wheel end apart yet. I'm going home after work to pull off the caliper and take a look around to see if there's any signs.
If anybody has any recommendations or thoughts on something I shoul checkout I would greatly appreciate it.
Thanks,
Luke
Thanks,
Luke
