Climate control problem
LSXHP
My GTP is a 99, problem I'm having is the climate control box (Dual climate control). When it displays the ext temp it keeps reading wrong. It will start at say 50* and slowly count up to the actual outside temp 1 degree at a time then begin to count down all the way to -39* and sometimes just stay there at which point its really say 90* out and my ac pump shuts off because it thinks its so cold out. This problem is intermminent but becoming much more common almost a daily thing lately. Any ideas on whats going on? I'm guessing either the climate control box itself is bad or where is the sensor that tells it what the outside temp is located at??:th_wtf:
On a side note my heated seat also intermintently quits working and dont seem to work much at all anymore and my HUD will get dim sometimes and then go dim then bright dim to bright over and over, could these all be related to a single problem?
that is the sure tale sign that the temp sensor is on its last leg.
This happened to be on my 2k replaced sensor and all was good
It does exist.......I dont know on this vehicle, but on other GM's I have owned it was in front of the radiator.....sorry I can't be of any real help.
Might want to give Ed Morad a call. He should be able to fix you up for MUCH less.
Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
I've had excellent service from Ed and he's saved me hundreds of bux.:th_thumbsup-wink:
Your signature says you sold the GTP. Whas sup?
+1 for morad or a local junkyard.........don't know the exact term for it other than the outside temp sensor...........
it says sold on the same line as the z28, so that is what i guess is sold....
