Cleaning Intake Ports
robinsone
I'm doing a LIM gasket and I was wondering if there is a good way of cleaning out the intake ports on the cylinder head. I wasn't sure if I could just spray it down with intake cleaner or if that will just gum up the area around the valves. I know there are different kinds of intake cleaner one which is used with the engine running. But I wanted to know if there would be any harm to cleaning out the intake ports when I have everything apart, thanks.
I wouldn't unless your going to take the heads off anything you spray is just going to go down into the engine and make it worse then before.
Sent from my SM-G920V using Tapatalk
They shouldn't be too dirty because the fuel injector sprays the fuel right into the cylinder head before the intake valve.
Brake cleaner and a scraper if you want, then vacuum anything you can out or use a pick.
If anything, clean the throttle body, LIM, and all the corresponding sensors.
Cleaning the intake ports on the heads...unless you're going totally through the engine, isn't worth the time.
I just got through doing this last week. I used a combination of gasoline, a tooth brush and an acid brush to get the black carbon off. For the reddish brown stains left behind, I used a brass wire brush and carb cleaner. Turned out real well.
