Clanking Sound
TeeWX
Well I just put 19's on my GTP and finally got my 3.2/XP Cam setup running and i went for a 5 minute drive at cruising speeds and literally every single bump sounded like the car was about to fall apart. It was making clanking sounds and stuff constantly unless I was on the brakes. I've heard the same sound before in the last car I owned and that was caused by a rim not being tight enough. Well, I torqued all of these to like 125ft lbs and did it twice to make sure and it sounds like all 4 are making noise. I don't understand what it could be. I measured the lugnuts it came with and the depth of the stud and it seems like they "shouldn't" be bottoming out.. that was my first guess... Anyone else had this issue? Thanks :\
whats the hub bore on those rims? is it big enough to fit where they are suppose to?
do you possibly need hub rings?
Hubcentric rings are probably not the case. This is a pretty loud clanking noise as if hitting two wrenches together.
A couple months back i was driving my GTP and everytime i cut the wheel on a turn it made a clanking noise too. Well i had my brother checked it out and turned out to be that my sway bar was broke. Check it out you never know. hope u figure it out.
