Bio248
DUI BABY
But a lot less cost.
id rather save myself time.
if you take the bottom end apart youre looking at a lot more work then just buying the short block.
it runs and being right are 2 totally different things.
Iit actually purred like a kitten after the plugs where replaced. Then it shed more aluminum and rattled away.Sorry... if the bottom end is ****ed, the car generally doesnt run well or at all...
i think what he is trying to say is, he rather pull it apart and inspect everything then just throw it in there.
he has 2 chiped pistions but the car was still running. hence running, and being right are not the same thing.
They don't do this unless your car is knocking.
So yes, GM could have designed a better exhaust, but the key is, nothing but 91+
Sorry I'm getting irratated by this problem. I just don't by the exhuast system being too restrictive because name a car from the factory that isn't restricted? I did notice a lot of heat checking on the front bank manifold which is no good,but still is that really the root cause of the problem? What about the ring gap theory? That makes sense too me under heavy loads and high heat. This car I have apart wasn't beat on....inless my ex was running 87 for a long time i just can't see what would do this kind of damage. The #1 piston is bad, I have seen worse but *******.The correct term is detonation. Also, don't call the knock sensor a knock sensor if you don't think it should be called knock...
If the exhaust is too restrictive, which the stock manifolds are, then your engine wont flow enough to safely handle the amount of air being pushed into the engine.
These cars do have knock sensors but if you push the engine hard when its knocking, theres nothing it can do. Sure it will pull timing, but its not a guarentee it will be enough.
Lets put it this way, you don't build a high compression or boosted engine, then push it on 87 octane... In simpler terms, you don't put street gas in a car designed for race gas then run the quarter mile.
Personally I'd like to know of a boosted car that can handle detonation.
Its called... an intercooler.
Pretty much all factory boosted cars have them cept ours because GM is too cheap. They made it run, but not safely. A fair number of stock cars knock even on 91.
