Check out this top swap!
He changed the V shape of the supercharger=worse efficiency than a stock supercharger GARBAGE.
BOOST Bypass valve mod is basically loosening the 1 bolt and changing the angle of the boost valve assembly. This makes the boost kick on faster. This is not good as it can lead to detonation. This is not a good thing, and the only time it really helps at all is if the valve doesn't close 100%. GM actually has a J-tool which is used to properly position the valve assembly correctly.
Jeez I did'nt know Stevie Wonder dropped his singing career ti do custom SC porting? Seriousl- thats a mess and this gu- should'nt be allowed to use power tools.
