MidnightGT
I am hoping someone out there can shed some light on my situation. For the past few months or so, my check engine light has been going on and off. The first time it went on it was raining heavily out and I just figured i hit a puddle or something as it went off in a couple of days. A couple weeks later it went on again so I took it to Advanced Auto and the code reported an emissions leak. I wasn't too worried about it and planned on waiting until my inspection was up to see if the mechanic could find the leak. Well, the light went off again within a couple of days so again I thought all is well.
I went for another month with the light not going on but then once it started to get cold (below freezing), the light again went on and my Remote Start had been struggling to get the car started. The remote start often failed on the first attempt (sounded like it started then shut off) but the second attempt usually worked but even then that didnt start it up always. I had a freak issue last year when leaving my girlfriend's parents house after a christmas party. It was probably around 10 degrees and snowing quite heavily with a good amount laying on the streets. Normally the car laughs at the snow for the most part but not this time. I started the car using the remote start to warm up a bit while i cleared the exterior snow off mine and my girlfriends. When I got in the car and put the key in, everything seemed to be fine as I sat there for a second. Then I put the car in Drive and started to drive away and that's when it seemed like a 4 alarm emergency. The ABS light went on, the Traction Control System disabled itself and if I remember correctly the Power Steering seemed "iffy." I was puzzled, turned the car off, restarted it and still the same issues. Great, when I need these features the most in a snow storm you fail me!! It was not a far drive home but it was a bit more interesting so i did it. The next day I started the car and it was a bit warmer out and everything was fine. It has not happened since but i have not been in conditions like that since either. Has this every happened to anyone else?
Back to the present... The check engine light is still on and now my Remote Start does not want to start the car at all. When I try it, I hear a click under the hood and a noise coming from the rear of the car (pump?) and that's it. It doesn't "turn over." It seems to start up fine when I use the key in the ignition. Does the Check Engine light and Remote Start issue correlate at all? I did not buy the car from a dealer but does it sound like only a dealer can help me? Recommendations are greatly appreciated and I aplogize for the long post.
