Check Engine Light: P0128 Code
mecsimm
I have a 2005 GP. Recently, the check engine light came on. I had it scanned, and it showed P0128: coolant temp below regulated temp. I do remember that it came on during a cool morning (45F). Is it possible the code will reset, now that temps are warmer ? Is there a certain number of engine starts that will clear it ?
Is there a way to clear the codes quicker, so I can see if it comes back ?
And lastly, is there a way to retrieve trouble codes similar to the way that older OBD-1 cars could ? You woul jumper the diagnostic terminal and count flashing lights for the number of the code.
temp sensor is under the t stat housing, bottom of the lim, just change it. look over the wires first tho, they could be bad.
I believe that code will reset, I had it on an impala with the 3.8 and it was stored as previous codes, but not a current code.
Use an OBD II scan tool to retrieve codes. They run as low as $50 to get a simple code reader, but you can go to an auto parts store and they will read codes for free.
No jumper wire techniques on OBD II, just a scan tool.
I fixed this issue by putting in a new thermostat (Also did a cooling system flush and new rad cap, the t-stat is what fixed the problem)
Hey Scotty u've helped me on the trans forum and now I have a new problem. P0128 code just came on. From what I hear its a bad thermostat? If so what brand/temp do I swap it with? Autozone says a 195 degree duralast? Is that correct?
All it's saying is it's detecting that the system took too long to warm up. "The intent of the P0128 code is to indicate a faulty thermostat."
Stant is a very common brand for thermostats, if you go with them get their superstat version. It's a few bucks more but is identical to oem.
Is it safe to drive the car for a day or two without damaging anything ?
