changing out struts
blackflag
I have removed the top 3 bolts and the bottom 2. I cant get the bolts out for the life of me. There seems to be too much pressure. Do i need to remove something else?
Ive already tried the hammer trick.
thanks-
Put the 3 bolts on top back in and try again on the bottom 2. Use a hammer if you mushroom the the knuckle bolsts just use a dremel or something to get them back in shape. Also make ire the whole assembly is hanging freely not jacked up.
