If it out of a Bonneville you will need to remove the front mount and front cover as the engine mounts are in different places. Learned that one first hand![]()
Don't swap the engine harness. I have no idea WTF Sheffer is suggesting that for. That would cause you a pile of issues because a 97 and 01 harness are totally different. To reiterate and add one thing.
Assuming GP motor to GP motor swap:
Swap TB to your original one
Swap Alt bracket/tensioner assembly to your original one
Swap Alt to your original one
Swap your fuel rail and injectors onto new motor (plugs are different on the injectors)
Drop it in and you are all set.
