BillBoost37
I've seen it hit 100% .. you haven't?
Why do you need it tuned?
Do you not know ANYONE that will pass it with a CEL even if you can prove it has a converter in it...or am I missing the issue...
I have the non-fouler trick on my rear O2 and don't have a code, Ill eventually need to replace the straight pipe 3" portion of my SD headers with a CAT (I have until may 2012, next emmisions test) Would a magnaflow (or any other prefered type) high flow 3" cat fit right in?
UCF04GPGTPCompG... do you have a bigger picture of your sig?
magnaflow make's the best high flow's i think
