Car won't start after repair
I appreciate the tip Jeff, THANKS
Yes, as Scotty said it is open to atmosphere so just leave it. Also use some small ty wraps to hold it on the tubing for the MAP sensor. Later after it's all sorted out you can replace all the hard lines with flexible line if you want. They will become more brittle with age. I had the one under the snout snap the other day. Came out for lunch started the car and it started to lope. Then the traction control and ABS turned off and it went into reduced power mode. Reduced power mode is bad. If you ever see this get it shut off as quickly as possible as it sets the engine at 15* AFTER TDC and full rich and you can burn up the cat in short order if left running in this condition for any time. It also locks you out of the throttle once you come to a stop.
Jeff
