Car Sputters
lol ok I did the evap canister the one by the rear gas cap last month and I just put a new EVAP Canister Purge Solenoid Valve in today the one on the back of the tb
i dont know the lay out of the sensors so well on the n/a engines. :o
double check the pig tail to the one on the engine, if you see bare wire, cracks or missing insulation, that wire is bad.
your tack looks like its waving at you....... that maybe a tcc solenoid issue you ever scan it for codes? even tho the light maybe off?
so update went and got my new vacuum elbow and new pvc valve kit both ac delco boom problem seems to be gone no sputtering when climbing through the rpms and when I let off the gas :)
We've been telling you its a vac leak forever, I even linked the p0507 dtc description on page 2. Glad you finally fixed the vac leak.
