NinetyEightGTP
Its like a 6-10 dollar part, don't get mad bro.
And takes literally 2 minutes to change.
well I'm sorta mad being that I bought the damn thing like 2 weeks ago.
maybe with the lower temps we've been having out side lately the t stat was working but being cooler out it was really working and you ran way to cool?
if it still runs to cold you may want to put a 195 back in for winter.
Now how did you manage that? The thermostat and gasket sit in the housing very snug before re-installing the upper portion.
Anyway I really don't think that will cause much coolant to be bypassed. Sure a little may leak through but it shouldn't cause any noticeable issues unless it leaks externally.
Also know that a 180° thermostat will run different temperatures in different seasons when un-tuned. My 180 runs about 190-195 in the summer and 185 in the winter. Same thermostat, just different outside temperature= larger cooling effect. The 195 thermostat would start to close preventing it from going below 195.
still doesn't make sense to cool the air coming in the intake and hope the block doesn't warm it back up.. I know its not that big of a difference but you say colder air helps... so why wouldn't a 25* lower block temp help? you fight tooth and nail for a 75* drop in temp with a ic but the block warms it +40* =net loss of only 35* IAT its a gain but not a nominal advantage... MY NUMBERS ARENT PRECISE just a point to be made, and don't tell me block temps and IAT's do not correlate that's just basic knowledge that that if cold air goes through a hot cylinder guess what the air gets hot...
because its tuned from the factory to run at that temp, its the ideal place the temp it runs at. you change the t stat and the car dont know why its running so much cooler then it should be, then tosses your mpg in the trash by over compensating the change you made.
cold air is dense air, more air molecules you can stuff in a engine the faster it will go or well the more HP it will make.
this is simple to under stand. normal air and fuel and spark, explodes. but more air plus fuel explodes bigger. same way a super charger or turbo works, more air the better, but now cool that air more and it becomes denser, so it adds even more air because its cold.
why do you think a GP is a dog next to a gtp? the supercharger is pumping more air into the engine.
