Car running hot
ShinyWhite99GTP
I have a 99 gtp. I have a k&n cold air intake, 3" bolt in down pipe with cat bolted to a stock exhaust, 180 t-stat, 3.5 pulley, autolite 104 spark pulgs. i just had the thermostat, pulley, and plugs put in yesterday. The car was running 2 notches below the large notch that is in the middle of 160 and 210 on the oil temp guage. As it later tonight it was running 3 notches away from 210, it never gets that hot. I read in the reviews on the zzperformance website that the gaskets that are sent with the thermostats are garbage. Anybody have any suggestions as to what the problem may be?
ok...you need a tune :th_jester:
now
with ANY pulley drop you NEED a tune, even the thermo needs tune
i installed the standard intense pcm, its amazing, i think im done with the engine now, im gonna get some 18' rims and lower it an inch or 2
He has a thermostat that kicks the fan on at the preset temp that he chooses. It's like the thermostat in your house.
PS- Dont buy a ZZP PCM. Before you ask why, do a search.
