i have a 98 gt. last year the ac worked amazingly. this year when i turn it on it makes sum wat of a squeling sound and usually the car dies rite away. the compressor isnt locked up.
Sounds like a bad compressor. It's putting such a load on the motor that it kills it. That squeal you hear is likely the compressor bearings seizing up and the belt slipping.
take the belt off to see if it stalls after you start it.
if the clutch on the compressor is shot, just buy a new compressor. changing its not worth it in the long run.
if you plan on doing this yourself, find a shop to vac out the a/c system for you, go home swap your compressor and its best to swap the orifice tube as well at the same time. take it back to the shop and re use your old R what ever it is that the shop has on hold for you. of course they will charge you to empty and refill your system but you know it was done right.
i noticed that when the compressor goes to kick on it makes a like hiss noise and does it when it kicks off. its not locked up to make the belt squel. but also noticed it sumtimes makes the gauges on dash go goofy and the trac control lite come on .
