Maybe
Well to start off my stupidity got me into this situation. I live in NY and as we all know it gets cold.
The LIM on my car leaks a lil anti-freeze, not much I add a gallon every couple months or so. Not much really. Well since this summer I have been adding water. Well we all know what happens next right. Yep my car radiator freezes. 1st I thought it was my heater core. Took hoses off ran water through and all went through fine. Next I replace my T-Stat. All good. then I get to my radiator. Frooze.
Well now I start taking it apart to get to the radiator I take off both hold downs. etc. to move it forward. Well to do this I had to move the large wire loom out of the way. Being cold it didnt really move well. But I got it propped over the radiator spout.
Now I get it all thawed out add anti-freeze
start the car let her idle up bleed it out and go to put the cap back on couldnt get it on, wire loom was in the way, mind you car still running, so I move the loom out of the way and the car just shuts off, no warning what so ever notta, just cuts out. So I test all fuses good. Then I check spark good. I press the lil tab and I get fuel so that is ok, I tried the trick with the fp relay and notta. Now I am at a loss. I did notice that one pink wire in that loom had a tiny and I mean tiny bare spot that looked a lil corroded other then that nothing. I am at a loss. I have no tuner, or code reader LOL is there any way to see if it is my pcm? Or do you guys have any suggestions? I am open to all suggestions. I know I know this is all my OWN STUPIDITY that caused this but live and learn, and hopefully my stupidity will learn someone else. Thanks for listening to me rant a little bit about myself LMAO and I am open for suggestion thanks
I do recall after thinking about it, I was getting the low t-stat temp code, and while I had it started before it even warmed up the cooling fans were on.
