car can rev up but wont come down?
Go under the hood (engine off) and pull up on your throttle spring and see if it springs back to home position. If it does, have someone push down the gas pedal and release. (also engine off) You watch and see if it does the same. If it doesn't return to home, your cable is sticking.
Thank you much
Beyond the knocking which I'm ignoring at the moment since you have the other thread. Would you like to give us some info about the issue? Currently there's not enough info to even talk about the problem.
