grandamle91
Is there a trick to getting the drivers side out, I've tried ply bar, bent my 4ft par. i've tried wrapping a rope around it and useing a tie down to pull on it. it moves about 2-3 cm.
It's a compression circlip that's holding it. If you put constant pressure, it's going to be super tight and likely going to fight the whole way at this point.
You might be better off pulling the passenger side, popping the output shaft out of the diff and pulling the axle with the output shaft. Then you can hold the output and beat the heck out of the back of the inner cv cup with it out of the car.
