I just installed an L26 block with S1X cam, double roller, 90# springs, Gen V blower, SLP Headers, built tranny with 3.29 single chain, 4340 IS, pump shaft, and 2750 zzp converter.
all these parts were in another car of mine except the L26 and they all worked with no issues what so ever. they are now in a different car of mine that ran prior with no issues with a stock L67 and tranny.
The car rattles/clatters when going up steep hills in 4th gear, doesn't do it in any other gear, doesn't do it at wot, only in 4th gear going up a hill. noise is on the Passenger side.
I removed the SC belt, noise goes away 100%.
Replaced the Tensioner with a used, known good, tensioner and pulley, noise remained.
Replaced the smooth idler with a new idler, noise was reduced, but still present.
Replaced the grooved idler with a new idler, no change.
Blower is tight, coupler is good, no odd play.
even tried a different belt no help.
I'm out of ideas, and can't find anything else that would cause this issue.
ANY HELP is greatly appreciated.
