Can Someone Identify the Blue Part on Top of the Engine?
Hurricane87
It doesn't appear in any of the engine diagrams I can find.
attachment.php
Also, what is supposed to attach to this fitting? We can't find a hose attached to it on either engine. Not getting any vacuum leak codes...
attachment.php
ive got a 5.3 in my tahoe, so not exactly the same set up, but my vac line from the top of the intake goes to a valve cover's pcv valve. its where you would install a catch can. between that line.
that other line looks fat enough to be evap related. im not even sure where im looking either in that pic.
It doesn't go into a valve cover, it's in the valley between them. The second picture is below and to the left of the throttle body.
Many LS engines have the PCV line into the valley cover and not the valve covers. But the LS4 should have a tube coming out of the rear valve cover that the PCV hose goes into.
The port on the intake manifold is likely another port used in a different applications. If you can put your finger over it and there is no air being sucked in, that port is blocked. My guess is that it's a PCV or EVAP line connection that just isn't used.
I cannot, of course, nail down the part number on the PCV hose for the LS4. However, every hose I can find is rubber or plastic. This thing is metal.
On my 08 that part is original and plastic, it goes to the port on the rear valve cover. The second picture that is a dummy post, nothing goes there and it has no vacuum.
You will have to contact a GM dealership directly for that.
The vehicle is over 10 years old and they don't have to make parts for it anymore. I don't see it listed on GM parts direct anymore so if there is a part number for that part, it's new old stock. They would have a complete parts list breakdown for it.
Or just do what anyone else would do and buy a piece of rubber hose to make a new one if you needed to do that.
No luck. I ordered that. It's black plastic and connects to the MAF sensor, not the engine. The one I have is just fine.
Anyone else?
