GOTIT4CHEAP16
Question in title...
Yeah they will be fine.
I dont mind getting 105 springs but i just wanted to check if they were needed or not.
Would switching my l76 springs for 105 springs and putting back my stock rockers all i need to do? The LS retainers on now can be used with the 105 springs correct?
So what are you deciding on?
Also a lot of people throw **** on the comp 105 springs... I accidentally ordered them and found out later that everyone goes with crow or "pro comp" springs. Well I've have them in for about 15,000 hard miles and they're in perfect condition.
They had a few bad batches when they moved production but I've only heard good things since.
...go by your method of thinking as well. In fact there is a regular on here with an XP'd, Intercooled, High Compression motor on L76's...runs like a raped ape. Commonly used for 1.9 rocker setups but they have been tried and true so far on VS/S1X/XP cars as well.have them in for about "X" hard miles and they're in perfect condition
Thanks for that useful post...I'll look into it...Right after I install a few XP's and S1X's with L76 and LS6 springs.
.............................maybe you should check your springs...see how they're doing. Hopefully you didn't get stuck with one of the bad Mexico batches like thousands of others did.
OP: Like stated, I ran LS6 Springs for over 40k...got rid of them and my XP for 130's and the Thrasher for my build. I daily'd the car for about 2 years that way then parked it and shoved it aside. On any aftermarket cam using the stock chain/dampner...I would however tell you to yank off the front cover and check the dampner every 50K or so...because depending on where the idle is set at, it could chew it up pretty quick. I had my idle set at 750. Dampner was almost gone after 40,xxx. Or you could bypass all this petty back and forth bullsh1t and get Manley 130's. Then you could really rev it and utilize every bit of the powerband of the XP and not have to worry about which valve springs to buy.
L76s are rated to .520 lift and the XP is like .536, and over .550 if you have a 1.66 rocker like some 3800 engines... at the installed height on our motors, which will usually come in a little shorter than 1.8, you're losing even more lift capability.
