Can anyone diagnose a possibly tune related issue?
Alright, 103's are a tad cold... You could try AL 104s or Factory iridium plugs. Do not get the platinum ones, the car hates those lol
Update: CASE relearn didn't help.
Contrary to what some believe... a case learn is ONLY to get the KR monitoring and misfire monitoring systems working correctly and accurately.
Get us a basic scan of the startup and warmup. If possible make sure your wideband is logged as well (Incredibly useful). Then we will go from there.
Thanks for all the replies. I'll post a scan late tonight when I get home, the wideband isn't installed yet, gotta do exhaust work for that.
Edit - any particular parameters? I did basics (boost, baro, inhg, kph, kr, rpm, etc), but can do another scan if it would be helpful to have other parameters.
Commanded Afr, o2 MV, long term and short term fuel trims, timing advance, ect, maf hz, maf lbs, map psi..... Those things.
