Camshaft Position Sensor Code
2002
Almost everyday the service engine light comes on. Every time i run it thru the scanner it comes up the same thing. I reset it everyday. it is p0341 wich is camshaft positioning sensor. why does this keep hapening?
Re: Important****
You could replace the sensor, but a lot of people that get this code, it ends up being a wiring issue. I would check the wires at the CPS sensor before buying another one. They aren't that expensive though. Usually around $50.
