camber bolts
nemesis
do i need one? my car is lower with ssc springs. when i ordered the springs i talked to zzp and they told me i don't need camber bolts. recently i read some threads at the other club and everybody said camber bolts are neccessary if your car is lower. my tires seem to be fine. the tread don't look like they wear out uneven.
I dont think you would need them I have put about 20,000+ miles on my car since the ssc install and my tires are wearing really even.
best way to tell is to take it to a alignment shop and have your alignment checked. you can order them if you want just to have them cause most likly you will need them at one time or another.
Ya, depends on the car, and how its needing aligned.
My car needed some for the back, and I only have the GMPP strut and spring combo, but they guy doing the alignment was able to make them from the stock ones. Its easy to do, take em to a grinder and make a lobe on them. He didn't charge me anything extra to do that, and makes fun of people who actually buy them.
Food for thought, if the alignment guy knows his stuff, he should be able to modify the stock ones just fine with no problems.
~F~
