suitercrew
Please do. I'll be ordering some from zzp tonight if I don't hear from you.I'll check today what I have, know they're Comp Cams, I'll check the length for stock.
Sent from my LG-H901 using Tapatalk
Ok well thanks for checking. Its under 100$ to get zzps shipped so no biggy.Just home and checked...
Comp Cams
7936
7.00
So, they're for Stock Rockers with Decked Heads...
Sorry
Intense doesnt have regular 5/16 .83 pushrods they only have them in oil restricted or if you upgrade to 3/8th but last time I checked you can upgrade to 3/8 unless you have head work or somethingI'd go with Intense PushRods... .83 wall as compared to .80 CompCams and ?ZZP's...
just sayin ; )
How easy is it to mess up the cam bearings? My dad is worried that with the limited space were going to have since we plan to leave the motor in the car, that "it will be difficult to install it without damaging the soft bearings" or is it one of those things that as long as your gentle and not a complete moron you'll be fine?
Sent from my LG-H918 using Tapatalk
You have a good point!intercoolers can leak fluid, vac leaks etc. cam just bumps and goes![]()
