Well the engine is down to nothing.. I just thought a quick rebuild wouldn't be that bad of a idea.. Curious to as why the engine wouldn't last long with new rings, bearings, bolts, etc.
the most common recommendation here when someone spins a bearing is to find a good short block, its cheeper than a rebuild and will last for many miles to come.
I understand if it spun a bearing that it would be trashed. I guess i'll have to do some more research.
I know it seems everyone thinks because a bolt has a spec of x plus x degrees that its torque to yield when in fact most of the bolts that have those specs in engines aren't even close to their yield/stretch torque.
I guess i'll ask the machine shop that's doing the heads what he thinks.
its one of those things with these engines, i know anyone with a like a 350 sbc would not think twice about popping open the caps and plasti gauging them all, these bottom ends don't like to even be opened and closed again.
I think it was Reptile that explained it to me. Something about the caps etc distorts when you pull them apart, therefore they require all the work etc.
Great engines when they are together, they don't like to be disassembled and put back together w/o the full boat of machining.
Yes...I'm a proud member of the 200 mile motor club.
Also FWIW our rings seal well w/o wearing much. At 186K I still had cross hatches in the cylinders and the rings were in such good shape we could have reused them as new.
Well I asked the guy that's been doing my machine work for years and he said that out if the 100+ 3800's that he's done, only one required the mains to be align bored.
The old deal with rods needing to be resized on the big end after new bolts was because the old bolts were pressed in.. As far as installing main studs the block captures and centers the mains on dowels... going from bolts to studs does nothing. I'll measure everything but I'm guessing i'll have no troubles..
I was do the is3 and heads and did it to freshen up. We reused the stock bolts. They were put in by someone has rebuilt many engines of all differnt makes.
