Burnt out light in shifter box
If you are talking about the lights in the center console to the left of the shifter, you pop off the top of the center console and its just a bulb
if it is a 04+ yes the whole console must be removed with the 4 screw by the floor.... and that is the reason mine will not be done.... because i had to remove it to put in my carbon fiber trim and it was a PITA... so it will remain burnt out
its not as bad as i described i guess... it just sucks cuz it is push the seat back take out the screw then push the seat forward take out the screw, then push the other seat back, then forward, and it just sucks, you will also probably have to pull off the radio trim and the empty din box at the bottom to make like easier. every other damn plastic part on the car has clips and that is the only darn piece of trim with screws.
Check the wheel and tire section, Bio has a good thread there and if its not covered then do a search then if you still cant find anything ask in the chat when bio or drunkie is around.
