Blackbeauty01
Ok so allow me to apologize ahead of time as I have not really dug into this too far yet, my tools are with my brother. However I just wanted to throw this out there for you guys that are more familiar with this engine.
This is what I do know..
It would appear that oil is escaping into the cooling system.
Cyl #2 has a misfire however it is not dead. The misfire is obvious, scanner says #2 and when I pull the plug for #2 it gets worse.
She is smoking out the tail, not bad enough to call the fire dept but enough to piss off the guy behind you. Oil not coolant.
She does not overheat even with the cooling system contaminated.
I really want to think it could be the LIM gasket, and not rings or valve train or head gasket.
So Ive got oil entering the combustion chamber and the cooling system, this is the only thing that steers me away from the rings and the valve train because the coolant would not come to play with either, however the head/lim gasket could. While I could have 2 problems everything started at once so I am hoping not.
Either way I have admired the GTP for a long time and if I have to get a low mileage drop-out so be it, the only thing that would suck about that is it would take a couple months for me to put that kinda cash away.
Any thoughts would be appreciated!
