bumper question
clevelandfan
im gettin the gt bumper for my se. my question is do the fog lights for the gt use the same plugs and everything as the se? i believe they should just plug in, but idk yet.
Some stuff behind the bumper is different but not the fogs.. If I remember right the GT has scoops behind the grilles & the lower plastic is different..
The GT bumper will mount the same as the SE bumper cover, Its a really quick easy job . IIRC there is one bolt on each side of the car *there is a space where you can see to stick a 10 mm (think its 10mm) socket in the fender well where the tip of the bumper cover and fender come together* One small 6mm screw in the center right by the hood latch and the rest are those plastic pop rivets which can be reused. If you need help hit me up on here and I'll see what I can do for ya.
correct. The lower plastic from the SE bumper (its that black plastic that is up behind the bumper cover etc) can be removed. When you install the cover you'll know what I'm talking about. I wish I had taken pics of mine when I did it.
Ya I kno how to do everything, and have all the parts. Was just curious if the fogs worked the same. Thx guys :th_thumbsup-wink:
