DaytonaGTP500
Hey guys im looking into doing a decent build over the winter and im jus a lil lost on all the decisions i have to make and want some input from everyone. The current setup is a zzp ported m90&lim, wizaird cai, zzp full size i/c, s/d headers with STOCK straight pipe to magnaflows, moded 1.9 rockers with l72 springs, solid mounts and self tuned.
I'm wanting to get a good cam/head setup with e85 and see if i can get up somewhere around 400hp. Ive seen the intense stage 3 package and the dyno numbers it put out but ive also seen the xpz cam had some pretty impressive numbers too, so im completley lost on what setup i would like. So if anyone has some input on good working/ bad working setups would be appreciated
Also is the stock bottom end good enough to handle that much hp, will a stock timing chain setup be good enough or do i need a double with balance shaft delete n all, and is there any other supporting mods(other than larger tb) that you can think of that i would need to get to my goal #'s. I havent ever really thought of going this far with it which is why i seem a little clueless i guess but all help is appreciated. Thanks guys
