Budget Comp G. 2.5" pulley = no belt slip
dsmuts
Moderator
I'm getting my comp g dropped off tomorrow with a blown motor so I'll be putting my L67 in it I've had laying in the garage for about 2 years. As of now the plans are s1x, p&p heads, and eventually fsic. I'm looking to hit 12's for under $4,000 including the car. I'll have pics up tom.
Running total:
04 comp g: $2200
Motor:
Open cone filter: $20
Port and polished heads: Free
S1X cam: $100
Timing chain & tensioner: $40
ZZP headers: Free
Gaskets for motor swap: $213
Reusable rocker bolts: $15
Head studs: $90
Yella Tella 1.8's: $150
Corsa catback: -$800
Trans:
300m: $315
7/8 chain: Free
Torque converter: $160.50
Looks
Reflective concepts stickers: $20
GXP spoiler: $60
Dna springs: $80
Aeroforce: $140
Sunroof since I broke my other: $150
Window tint: $171
Tinted led tails: $80
Headlights: $90.99
Interior trim piece: $5
Inferno Hood: $525
Maintenance:
New KYB excel-g struts: $233.40
Wheel bearings: $80.50
Parts sold off car:
Cat: -$100
LIM: -$40
Heads: -$150
Grand Total $3849.39
Re: 04 comp g Project cheap
Under $4k, eh?
Just dropped off :D I'm going to change the oil in it and see what we have. I don't hear the motor knocking at all right now and the guy told me he change a lifter out so fingers crossed the motor can be saved.
Re: Budget 04 comp g running total $2200
I'm going to see if the motor can be salvaged first. Josh there will be more soon I still have to go out and look at the motor and see what can be done. I'll snap pics when I go out.
No rust but horrible misfire. I took it down the road after the oil change and I don't think it's rod knock but it's hard to hear over the exhaust leak. Does a 97-03 dp fit the 04+? I think I might swap the dp and listen a little better.
Nice color..Happy for you!!..Hope it all works like a charm..
Nice find, hope you can slavage her. I think the 97-03 dp will bolt in just fine, but on 04+ the cat is moved even farther forward so you might have alittle trouble with the oxygen sensor wires reaching. You can always make it work.
Ok thanks I'll swap them out tom when I get a chance. I took a few more pics when I changed the oil in it.
Interior needs cleaned pretty bad
Rims are in pretty bad shape
Hood dent. It's not to bad
It'll get pretty. I want it to get running good first lol. What color do you guys think I should paint the motor if I do end up swapping it out?
