Bryant changes his mind faster than any woman...and some Cam Help...
Re: help after cam install :(
yes ok here is every mod i did lol.
xp cam
105# springs with mod'd retainers
new valve locks
new OEM timing chain and tensioner
AC delete pulley
that is all as of now
ok smart ass :p haha for real i need to get this taken car of so i can tune it and get it running good. i hope its jsut the flex plate bolts. what do they torque down to?
No, it's fine... Nicks an end of worlder.,.,.
I have never bought new ones and done hundreds of swaps,.
well i jsut got done with my car. I checked the flex plate bolts and they were all tight. With the stethascope it sounds like its coming fromt eh cam areas. aka... flex plate or timing chain. between there... and now it makes the grinding noise at idle.
aka flex plate and timing chain area...those are on opposite ends of the motor brah.
Cam area is still by the timing chain...so...go pull off the front cover
bill and nick talked it over in the chat. they said it sounded like the crank sensor guard rubbing the balancer.
or you need to tighten your rocker bolts again.
does grinding = high frequency tapping? like a rocker is loose? and a pushrod is bent?
nick did look at it duhhhh.
no grinding means rub rub rub of 2 thigns lolol. Im just saying this does not sound like plastic
