Here is the story of my Broken Transmission.....
when leaving a stop light i lost all forward motion, sounded like a sonic boom when off underneath the car...not good.
so the car was taken to my house and put in the drive way, (piggyback #1) while i had thoughts of setting the car on fire
I located a Trans, and it HAD to be from a 2003 Bonneville or Lesaber, due to the Internal Wire Harness, Valve Body, temp sensor Etc. I was able to locate a trans had it delivered to Wyotech (where i work).
Saturday Morn it gets Piggy back ride #2 from my house to Wyotech
Get it in the shop and start working
first time to take a look underneath Nothing broken externally (duh)
Available tools
all the connectors disconnected and engine support in place
Subframe out pass axle out
Trans ready to come out
Trans out yay :roll:
Get the Drivers side Mount, HD Diff, Sun Gear, Output shaft and the HD cover Swapped in to the JY trans.
Uhh this is bad.
So i have to swap my good Side cover with the broken one.
No pics of the reinstall but imagine the reverse order of the pics
and finally
and the Broken Parts
Available tools
Uhh this is bad.
and finally
