Broken input shaft? help please... Trannyman?
if you were to install these seals for me, how much would you charge?
and also, how is somebody expected to install these seals when purchasing this input shaft?
i know u can choose the option from zzp for an extra $10
the shaft is getting shipped to me today, so ill have it later on in the week, and i need my car ASAP, and im also kinda broke
any ideas?
I also charge $10 to install new seals on the input shaft and shipping USPS Priority should be $6 and take 2 days to most areas. Intense only sells their input shafts with the rings installed. ZZP gives you the option to save a few $$$ as most guys are installing the input shaft with a rebuild or having a rebuilder install the shaft. New seals are included in a rebuild kit and should be replaced anyways so often you dont need the seals already installed on the input shaft.
well back from the dead, just wanted to say thanks to trannyman and everybody else for the help
the trans has new valvebody gaskets, input shaft sleeve, channel plate gaskets, 4340 input shaft, and gxp drivechains
trans is back in the car and it runs, so im very happy, and also excited i did it myself!
the GXP chains essentially look the same as the stock chains, they are Morse Hy-Vo, but they have a different number on the links than the other one did obviously
thanks again for the help, just wanted to drop an update!
