Brand used transmission
ok,so check it out,i took my car to the shop to get the differential changed out and the guy tells me it would take a day or two and i didn't have a ride back that day,so i went back to the wrecking yard and asked the guy if he gave me back some money back i would do the work myself and he agreed and gave me $100 back so i paid $400 for a 06 trans .
so today i did the work with the tranny in the car , only had to take off the tire and trans axel and disconnect the strut and rotor.
i followed the info i got from BILLBOOST37 to change the differential, i used my original one from my 04 .please note THERE IS A B I G DIFFERENCE IN THE GEAR RATIO ON THE 04, IT'S A LOT SMALLER THEN THE 06, BUT AFTER THE CHANGE MY CAR RUNS GREAT. THANKS BILLBOOST37.i will do a wright up on it later after i get some more pictures, i have the whole job well i did it but need other's to give everyone a good view and how too.PEACE.
I thought changing the diff doesn't change the gear ratio of the trans just HD vs Non-HD? Unless you just had a bad diff.
Edit- Never mind..I saw that you can get a 3.05 final drive diff.
@pure2sin , after going back to the yard I got the tranny from , I looked at the motor it was connected to they had 06 marked on it and it wasn't s/c , when I put it in, it would shift hard , so I took it to get reprogrammed but the guy said it was the wrong gear ratio and if I just changed the differential it would be fine. So I changed it and guess what.... It runs sweet now !!! And the gears on the 06 were bigger then my original one's from my 04.
Well I didn't take them out, I just disconnected them to move the spindle out of the way a little bit, but a screw driver n hammer worked out fine to get the differ out , whole job took about an hour 1/2.thanks for the help bro.
