hi there. recently I removed my throttle body for cleaning and was told on the forum by a member that I should disconnect the battery afterwards in order to wipe the memory of the ecm, so that it could begin to relearn the throttle settings, which I did. yesterday I was driving and I got a message on the display saying low brake fluid, so I checked and sure enough my rear drivers side caliper is leaking.
I was wondering if anyone knows if there are sensors that control the pressure from the master cylinder that may have been messed up when I flashed the memory to the ecm. If so that would explain why the caliper is leaking and then I would know to not simply repair the caliper, but also have the car connected to a scan tool to have the settings put back how they should be. Thanks for any help.
