94grandprix
What are the symptoms of a bad break booster besides spongy breaks,is the cruise control connected to it since it runs off vacuum
Hi Scotty:
I have the same issue, but it isn't wet under where the master and booster connect, although I see some rust/corrosion on the lower part of the booster drum. Fluid is disappearing somewhere, not leaking under wheels or anywhere under car, so I suspect it is leaking from the back of the master into the booster. Would I need to replace the booster too? What do I do if I discover a pool of brake fluid in the booster? Will it eventually get sucked out and burned in the exhaust?
Thanks
