Braided Fuel line for only $15
Z34Phoenix
Florida Tuner
Ok I had a set years ago and never used them... then lost them when i moved. So i got another set. the 95 Lumina APV mini van with a 3800 comes factory with braided fuel line. not sure why they went with them but hey! good for me. they seem to be the same length as my l36 lines and will do nicely when i install the top swap as i can use the same fittings i used to install the l36 lines when swapping from the DOHC. just figured everyone could use the info.
Toss us a bit more info about the way you connected etc. That would be a score ....if there were any Lumina dustbusters in the yards.
Ok I used compression fittings like these for when I swapped to the L36 lines from the LQ1 (DOHC). I left the metal line intact on the lines on the L36 set and also for this braided set. I cut the lines on the car back to the hard metal as well.:
images
