Brackets for Pilot fog lights......
Iron Indian
I know many of you have aftermarket fog lamps. How are you guys making custom brackets to make these work? I'm looking for a setup that will reuse the stock adjustment setup, much like the MSP brackets do. I'd rather make some than to spend $40 + shipping for some damn brackets.
BTW, I have 4" Pilot Fog lights from Autozone....
I seen a nice little write up
for making brackets and i will look for it for you.
Off hand i do not remember were it was i seen it
but as soon as i find it i will post it up...HTH's
i recently put these fog lights in my 04 grand prix gt with tin flashing...i took a little piece and stuck it behind the factory fog light hole and drew the circle of the fog light hole...then marked where the factory hangers are for the factory fog lights to put holes in the flashing where bolts were used to hold it in place..i then placed the halo fog lights somewhat centered in the hole that i drew from the factory fog lights and traced them but i didnt cut the exact circle from the halo fog lights so the outer lip on the halo fog lights would catch the flashing and not pull through..i cut the circle out for the halo lights except for a two little square tabs located in line horizontally with the factory hanger holes which can be bent back and have holes drilled in them to screw the halo fog light brackets to..i also sanded the flashing to give it a brushed aluminum look which was very nice..let me know if you have questions or want pictures!!
I could not find the write up but am still looking for it ok..
The Angel eyes are alot like those piolet lights though
and if you take the braket that came with them you can mount that to the stock one to install something like this.. HTH
Here is the info for you
sorry took so long to find it hope it helps out..
After buying them yesterday I installed them today.I used the wiring harness that came with the lights and I used the existing power to power up the relay using the purple wire of the OEM fog light wiring. I used the black one to ground the lights.
Then I put the relay beside the fuse box under the hood and grounded it with the self tapping screw to secure the relay and attached the power wire to the top of the fuse box.
Then I used the stock brackets and bolted the brackets that came with the lights to them
Then I installed them into the bumper
I used the white wire that came with the wiring harness to bring power to the lights and put everything back together. Here is the finished product. Those lights are very bright. I would say at least twice as bright as the OEM.
Hope this will help some people that want to do this mod. It is not that hard to do just take the time to make proper connections and run the wires and tie them up with zip ties to hold them in place.
